		<title><![CDATA[SERVICE CORE FORUM &mdash; PC is dead after sleep mode]]></title>
		<link>https://service-core.com.ua/forum/topic104-pc-is-dead-after-sleep-mode.html</link>
		<atom:link href="https://service-core.com.ua/forum/feed-rss-topic104.xml" rel="self" type="application/rss+xml" />
		<description><![CDATA[Недавние сообщения в теме «PC is dead after sleep mode».]]></description>
		<lastBuildDate>Fri, 26 Oct 2018 12:44:57 +0000</lastBuildDate>
			<title><![CDATA[Re: PC is dead after sleep mode]]></title>
			<link>https://service-core.com.ua/forum/post632.html#p632</link>
			<description><![CDATA[<p>Hi,<br />trouble with sleep mode is possible for several reasons. For starters, it is worth updating the BIOS version on your motherboard. It is also worth updating the driver for all devices. If this does not fix the trouble, then you need to try to replace the PSU - it is probably his fault.</p>]]></description>
			<pubDate>Fri, 26 Oct 2018 12:44:57 +0000</pubDate>
			<guid>https://service-core.com.ua/forum/post632.html#p632</guid>
			<title><![CDATA[PC is dead after sleep mode]]></title>
			<link>https://service-core.com.ua/forum/post580.html#p580</link>
			<description><![CDATA[<p>Hi,<br />I have trouble with my pc, the point is that when I put him into sleep mode, I cannot wake up him after.&nbsp; When I click on my mouse to wake up pc from sleep, only mouse light is lit, but no pc fan is spinning, on front panel of the case I notice that sleep LED is slowly blinking indicating that pc is in sleep mode. When I press power , nothing happen, when I press and hold power to turn off, nothing happen, when I press reset also nothing happen. So ultimate solution to turn on my pc is to switch the button on the psu to off and on again.. even after that my pc does not turn on, nothing happen. But I manage to turn my pc again only after some time. This problem persist for me like more than 2 weeks, and whenever I attempt to put my pc into sleep, I always should experience this..&nbsp; Also I remember once when I turned the pc off and immediately attempted to turn it on again, same happened, it did not wanted to turn on. However I always manage to turn it on back after some time..</p><p>I using Asus m2n-e motherboard on win7 32bit</p><p>Any suggestions would be appreciated.</p>]]></description>
			<author><![CDATA[null@example.com (fritel)]]></author>
			<pubDate>Sat, 20 Oct 2018 18:07:01 +0000</pubDate>
			<guid>https://service-core.com.ua/forum/post580.html#p580</guid>
