Тема: Share experience to play Asian handicap 1/4 and win big
Asian handicap is a familiar type of bet chosen by many, among which the 1/4 handicap or 1/4 ball handicap is one of the popular odds in Asian handicap betting. So what is the 1/4 handicap? How to play 1/4 handicap? What are the experiences to win big on 1/4 handicap? Please follow the verified soccer tips below on Wintips for the most accurate answers.
Understanding the 1/4 handicap
To understand what the 1/4 handicap is and how to play it to win most easily, first, you need to grasp some basic knowledge about Asian handicap betting.
Concept of Asian football handicap
Asian football handicap (or simply Asian handicap or handicap bet) is used when there's a difference in quality between teams in a match. This is the fundamental type of bet offered by Asian bookmakers.
The stronger team will be the favorite (the top team) and the weaker team will be the underdog (the bottom team). Offering this type of bet aims to create fairness when you bet using Asian handicap odds.
Asian handicap betting occurs within 90 minutes (plus injury time) of the match, excluding extra time. During the match, bookmakers may adjust the Asian handicap odds for the first half, second half, or extra time.
What is the 1/4 handicap?
Betting on 1/4 (quarter ball handicap) is one of the most favored bets in the world of online football betting.
The 1/4 handicap means that the favorite team (the stronger team) is given a slight advantage over the underdog team (the weaker team), so half of your stake will be returned. If you bet on the favorite team and they win, you win; if the match ends in a draw, you will get half of your stake back; if you lose, you lose the entire stake. If you bet on the underdog team, the opposite outcome applies.
To understand more about the 1/4 handicap and how to play it, let's look at some examples:
In a match between Chelsea and Liverpool, both teams are evenly matched, but since it's Chelsea's home ground, the bookmaker sets the handicap at 0.25. Chelsea is the favorite with odds of 0.97 and Liverpool is the underdog with odds of 0.93.
If you bet 1000K on Chelsea:
If Chelsea wins the match, you win this bet with 970K because the odds are 0.97.
If the match ends in a draw, you lose half of your bet, which is 500K.
If Liverpool wins, you lose the entire 1000K.
If you also bet 100K on Liverpool:
If the match ends in a draw, you win this bet and receive 930K because the odds are 0.93.
If the match ends in a draw, you get half of your winnings, which is 500K.
If Chelsea wins, you lose your entire bet.
Find out more : what is an asian handicap bet
Experience playing 1/4 Asian Handicap for Big Wins
Knowing what a 1/4 Asian Handicap is isn't enough; to win big on this type of bet, you need to equip yourself with the experience of picking the right odds.
First and foremost, you need to thoroughly understand the match, as well as the head-to-head records of the teams, while also considering the opinions of experts. If one team has recently performed better and is highly rated by many experts, then you should place your bet under the 1/4 handicap line.
For some odds below 2.25, you can choose a lower betting amount, and while watching the match, you can have a clearer picture of the winning odds. When the favored team is handicapped by 1/4, if there are no goals in the first half, the handicap still applies in the second half, but the odds for under 2.5 goals in the second half are very low, ranging from 0.8 to 0.85, which can be bet on the under.
If both the full match and the first half end with a score of 0-0, then in the second half, the bookmaker still handicaps by 1/4, but with a 1.5 goal handicap in the second half, you can go for over goals when betting under.
In a similar situation but with lower odds for betting under, around 0.65, if the odds for a draw in the match are also under 0.65 and extend until the end of the second half, then you should go for the over and bet on goals. Especially with a 1/4 handicap, if you lose in the first half, keep betting under in the second half and go for goals.
Above is an introduction to what a 1/4 Asian Handicap is and sharing a straightforward and accurate way to interpret it. Hopefully, these soccer tips app experiences can contribute to your success in sports betting. Finally, I wish you all good luck and plenty of enjoyable entertainment experiences at reputable bookmakers
