Тема: What is a Total Goals Bet? Expert Tips
Football has always been known as the king of sports, warmly welcomed by people everywhere. Football betting is a game that emerged based on the results of this king of sports. In football betting, there are countless types of bets, such as extra time bets, Asian handicap bets, European handicap bets, and total goals bets. Let's learn about what a total goals bet is, the rules of the game, and some expert betbook betting tips
A total goals bet, also known as an over/under bet or a total score bet, frequently appears on the betting boards of various bookmakers. As the name suggests, this type of bet is straightforward to understand. Players predict and place bets on the total number of goals scored in a match between two teams during the 90 minutes of regular play.
This type of bet is unique because you don't need to determine the winner or which team scores. All you have to do is place your bet based on a specific number set by the bookmaker.
The bookmaker will provide a specific number, say A. You then place your bet based on the perceived difference in the strengths of the two teams, choosing either over or under that number. You place an under bet if you think the total number of goals will be less than A, and an over bet if you think the total number of goals will be more than A.
https://img.freepik.com/free-psd/realistic-football-landing-page-template-design_23-2149353646.jpg
View more articles : betting tips group on telegram
Some Popular Goal Betting Odds
After thoroughly understanding the rules and gaining basic information about what goal betting odds are, let's explore some popular betting odds.
What is Goal Betting – Odds 0.5 With the 0.5 odds, there are two specific scenarios when you place a bet:
If you bet on the Over, you win the bet and the money if the total number of goals at the end of the match is greater than 0.5.
Conversely, you lose the bet and the money if you bet on the Over but the total number of goals at the end of the match is less than 0.5. In this case, those who bet on the Under will win.
What is Goal Betting – Odds 0.5/1 For these odds, there are three specific scenarios:
In the first scenario, if you bet on the Over, you win all the money, and those who bet on the Under lose everything if the total number of goals at the end of the match is greater than 2.
In the second scenario, the opposite happens: if you bet on the Over, you lose, and those who bet on the Under win, provided the total number of goals after 90 minutes is 0.
In the final scenario, if you bet on the Over, you win half the money, and those who bet on the Under lose half the money when the total number of goals at the end of the match is 1.
Other Odds There are still other odds such as 1, 1/1.5, 1.5, 1.5/2, etc. The method of calculating the bet and goals is the same as the two odds above, only the number of goals after 90 minutes changes.
Some Experiences with Goal Betting
Goal betting is considered quite simple and easy to win. However, you need to understand some experiences to improve your chances of winning and reduce the risk of failure.
Analyze and Understand the Strength of Both Teams: For any type of bet, understanding the strength and form of the teams is crucial. For goal betting, you need to understand the relative strength of both teams, compare their strengths and weaknesses, and study the line-up to bet accurately.
Choose the Right Tournament to Bet On: You should choose major tournaments to bet on, as the teams participating in major tournaments are usually well-known and provide more information for you to analyze and understand.
Conclusion
Through the article "What is Goal Betting?", and experiences gathered from actual bets, we have helped you grasp the basic information betting tips app about goal betting. We wish you good luck and big wins in sports.
Re: What is a Total Goals Bet? Expert Tips
Beş ildir ki, onlayn qumar dünyasının içindəyəm. Amma mən o adamlar kimi deyiləm, bilirsən, kim ki, son qəpiyini qoyur və ulduzlara dua edir. Mən bu işə iş kimi yanaşıram. Riyaziyyat, statistika, soyuq hesablama və bir az da intuisiya. Əsas silahım isə həmişə təmkinli olmaqdı. Ən böyük qorxum isə bir gün sistemin sıradan çıxmasıdı – nə mənada, əlimdəki pulun qəfildən “buxarlanması”. Ona görə də hər uduşdan sonra etdiyim ilk iş, pulu çıxarmaq olur. Və bu mənada mostbet minimum withdrawal məbləği mənim üçün heç vaxt problem olmayıb. Əksinə, bu rəqəm mənə həmişə nizam-intizamı xatırladan bir meyardı.
Mən adi bir ofis işçisi idim. 2019-cu ilin yazı idi. İşdən çıxdıqdan sonra axşamlar evdə oturub basketbol analiz edirdim. Qardaşım dedi: "Məzəli deyilsən, komandaları tanıyırsansa, niyə mərc yazmırsan?" Mən də ciddi yanaşdım bu işə. Əvvəlcə kiçik məbləğlər, sonra sistematik yanaşma... Və bir gün anladım ki, bu, sadəcə şans deyil, bu, bacarıqdı. Artıq üç ildir ki, professionel oyunçuyam. Yəni, mənim üçün kazinoya gəlmək, fəhlənin səhər fabrikə getməsi kimidir. Sadəcə, mənim alətim siçan və klaviatura, fabrik isə virtual zalddı.
Keçən həftə başıma gələn hadisəni heç vaxt unutmayacağam. Gecə saat 3 radələri idi. Evdə tək idim, sakitlik, ancaq kompüterin səs-küyü. Adətən mən slotlarla oynamıram, daha çox poker və ya idman mərcləri. Amma həmin gecə gözüm bir oyuna sataşdı. Qərar verdim ki, bir az "əylənim". Strategiya sadə idi: müəyyən büdcə ayır, uduzsan çıx getsən, udsan da dayanmağı bil. 200 manatla başladım. Adi mərc, adi döndərmələr. Bir an gördüm ki, balans artdı, 300 oldu, sonra 400. Və birdən-birə ekranda işıqlar yanıb-sönməyə başladı. Mükafat oyunu! Ürəyim döyünür, amma özümü sakitləşdirirəm: "Bu, sadəcə oyundu, Sadəcə oyun". Mükafat raundunda 3 ədəd "7" rəqəmi düşdü. 5000 manat!
İnan, o an əlim ayağım boşaldı. Beş ildir bu işdəyəm, bu qədər böyük uduş görməmişdim bir gecədə. Amma peşəkar refleksim işə düşdü: düyməni bas, pulu çıxart! Düşündüm ki, 5000 manatı çıxarmaq üçün mostbet minimum withdrawal qaydası mənə mane olacaqmı? Xeyr, əlbəttə. Limitlər aydındı, sistem işləyirdi. Əmr verdim, pul bir neçə dəqiqəyə kartımda idi. Və yalnız bundan sonra dərindən nəfəs aldım.
Sonra maraqlı şey oldu. Həmin gecə udduğum pulla səhər durub getdim özümə yeni bir noutbuk aldım. Köhnəsi artıq yavaş işləyirdi. Bilirsən, bu hiss çox gözəldi: qumar oynayıb, qazanıb və həmin pulla öz iş alətini təzələmək. Peşəkar futboçunun yeni butslar alması kimi bir şey.
Amma mən heç vaxt demirəm ki, bu asan yoldur. Əksinə, çox çətin yoldur. İntizam tələb edir. Mən hər uduşdan sonra ən azı 30% kənara qoyuram toxunulmaz fonda. Və heç vaxt "qızğın an"da qərar vermirəm. Həmin gecə 5000 manatı çıxardıqdan sonra bir qəhvə içdim, 15 dəqiqə gözlədim və yenə oyuna qayıtdım. Amma bu dəfə başqa məqsədlə. 100 manat ayırdım, dedim, əylənək. Uduzdum həmin 100 manatı, güldüm və kompüteri bağladım. Çünki mən qazanmaq üçün oynadığımı bilirəm, itirmək üçün yox.
Dostlarım tez-tez soruşur: "Qorxmursan ki, bir gün uduzasan?" Qorxuram. Amma mənim qorxum uduzmaqdan deyil, idarəni itirməkdi. Məhz bu səbəbdən mostbet minimum withdrawal məbləği mənə hər dəfə xatırladır ki, sən pulunu nə qədər tez çıxarsan, bir o qədər az risk edirsən. Bu, qumarbaz üçün yox, professionel üçün qaydadır. Mən bu qaydanı pozmuram. Və bu qayda mənə hər ay sabit gəlir gətirir. Bəli, bəzən itirirəm, bəzən qazanıram, amma ilin sonunda həmişə artıda oluram. Bu da mənim işimin qanunudur.
Sonda demək istəyirəm ki, bu dünya hər kəs üçün deyil. Əgər özünə nəzarət edə bilmirsənsə, yaxşısı girme. Amma əgər beynini işə salıb, emosiyaları kənara qoyursansa, bu, əsl peşəyə çevrilə bilər. Mən öz peşəmi sevirəm. Və həmin gecəki 3 ədəd "7" rəqəmi mənə sadəcə pul yox, həm də öz qaydalarıma olan inamı qaytardı.
